  • Kaiser Creative Studio 3 posts 73 karma points
    Mar 04, 2019 @ 21:13
    our.umbraco.healthchecks package error when running checks
    I have installed our.umbraco.healthchecks on an Umbraco site running 7.12.4 but I am getting an error when I run the checks. The site will be hosted on Azure.
    Here is the error:
    at Our.Umbraco.HealthChecks.Checks.Azure.AzureLoggingCheck.get_CheckSuccessMessage()
       at Umbraco.Web.HealthCheck.Checks.Config.AbstractConfigCheck.GetStatus()
       at Umbraco.Web.HealthCheck.HealthCheckController.GetStatus(Guid id)
       at lambda_method(Closure , Object , Object[] )
       at System.Web.Http.Controllers.ReflectedHttpActionDescriptor.ActionExecutor.<>c__DisplayClass10.<GetExecutor>b__9(Object instance, Object[] methodParameters)
       at System.Web.Http.Controllers.ReflectedHttpActionDescriptor.ActionExecutor.Execute(Object instance, Object[] arguments)
       at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task)
       at System.Web.Http.Controllers.ApiControllerActionInvoker.<InvokeActionAsyncCore>d__0.MoveNext()
       at System.Web.Http.Filters.ActionFilterAttribute.<CallOnActionExecutedAsync>d__5.MoveNext()
       at System.Web.Http.Filters.ActionFilterAttribute.<ExecuteActionFilterAsyncCore>d__0.MoveNext()
       at System.Web.Http.Controllers.ActionFilterResult.<ExecuteAsync>d__2.MoveNext()
       at System.Web.Http.Filters.AuthorizationFilterAttribute.<ExecuteAuthorizationFilterAsyncCore>d__2.MoveNext()
       at System.Web.Http.Controllers.ExceptionFilterResult.<ExecuteAsync>d__0.MoveNext()
       at System.Web.Http.Dispatcher.HttpControllerDispatcher.<SendAsync>d__1.MoveNext()
    And here is the log4net config file:
    <?xml version="1.0"?>
    <log4net>
      <root>
        <priority value="Error"/>
        <appender-ref ref="AsynchronousLog4NetAppender" />
      </root>
      <appender name="rollingFile" type="log4net.Appender.RollingFileAppender">
          <file type="log4net.Util.PatternString" value="App_Data\Logs\UmbracoTraceLog.%property{log4net:HostName}.txt" />
        <lockingModel type="log4net.Appender.FileAppender+MinimalLock" />
        <appendToFile value="true" />
        <rollingStyle value="Date" />
        <maximumFileSize value="5MB" />
        <layout type="log4net.Layout.PatternLayout">
          <conversionPattern value=" %date [P%property{processId}/D%property{appDomainId}/T%thread] %-5level %logger - %message%newline" />
        </layout>
        <encoding value="utf-8" />
      </appender>
      <appender name="AsynchronousLog4NetAppender" type="Log4Net.Async.ParallelForwardingAppender,Log4Net.Async">
        <appender-ref ref="rollingFile" />
      </appender>
      <!--Here you can change the way logging works for certain namespaces  -->
      <logger name="NHibernate">
        <level value="WARN" />
      </logger>
    </log4net>
    Mar 06, 2019 @ 19:59
    Does anyone know what might be causing this error?
