I have been struggling with this for a few days now and nearly have it but just can't seem to get it right.
I have a number of testimonials that are catagorised by a drop down menu.
I wish to display the catagory testimonial on the catagory page. ie painting testimonials on the painting page. And when there are no catagory testimonials a random testimonial is displayed from any catagory.
To control the display of the catagories I have a variable
var testip = Model.Content.Site().FirstChild("Testimonial").Children().RandomOrder().Take(1).Where(x => x.HasValue("testimonialCatagory") && x.GetPropertyValue<string>("testimonialCatagory").Equals("Painting"));
This works fine
The variable that displays any testimonial is
var testiall = Model.Content.Site().FirstChild("Testimonial").Children().RandomOrder().Take(1);
This works fine if the catagory has more than one testimonial. But if the catagory only has one testimonial there is sometimes a blank where the testimonial should be and then it appears. This also happens if there are no testimonials.
There are 12 catagories hence the else if statements.
// Your chaining is incorrect:
// you are taking one - before you check the condition
// so if that first one isn't a "Painting" then you won't take anything so testip will be empty.
// so the "where" clause should go before the take.
// you filter then take.
// use firstordefault - dont need foreach with first or default
// rename variables to be more meaningful
// also why is there an empty anchor link?
// also dont use <b> use <strong>
// don't duplicate same html
// put the conditional around the image element instead.
// change the 2nd conditional "else if" - it's not required as always results in true.
// refactor and put code into a helper
// get 1 random painting testimonial
var paintingTestimonial = Model.Content.Site().FirstChild("Testimonial").Children().Where(x => x.HasValue("testimonialCatagory") && x.GetPropertyValue<string>
("testimonialCatagory").Equals("Painting")).RandomOrder().FirstOrDefault();
// 1 random testimonial
var randomTestimonial = Model.Content.Site().FirstChild("Testimonial").Children().RandomOrder().FirstOrDefault();
@if (Model.Content.Id == 1074 && paintingTestimonial != null)
@renderTestimonial(paintingTestimonial)
else if (randomTestimonial!= null)
@renderTestimonial(randomTestimonial)
@helper renderTestimonial(IPublishedContent testimonial)
var companyLogo = Umbraco.TypedMedia(testimonial.GetPropertyValue<string>("testifierCompanyLogo"));
if (companyLogo != null)
<div class="well">
<div class="testimonial">
<p>@testimonial.GetPropertyValue("testimonialText")</p>
<b>@testimonial.GetPropertyValue("testifierName")</b> - <i> @testimonial.GetPropertyValue("testifierCompany")</i>
@if (companyLogo != null)
<img paintingTestimonial="@companyLogo.Url" />
<a href="@testimonial.Url"></a>
Lol, I completely rewrite the code for you, you modify it slightly outside the parameters of your original question, then mark your own code as correct. shakes head
Random display of testimonials
I have been struggling with this for a few days now and nearly have it but just can't seem to get it right. I have a number of testimonials that are catagorised by a drop down menu. I wish to display the catagory testimonial on the catagory page. ie painting testimonials on the painting page. And when there are no catagory testimonials a random testimonial is displayed from any catagory.
This works fine
This works fine
To display the elements I have
Does anyone have any ideas?
Thanks Matt
Thanks for pointing me n the right direction
I am learning alot. Did not know about the @helper.
Got there in the end with just a few modifications
