  • Mark Watson 118 posts 384 karma points
    Mar 27, 2019 @ 06:35
    Mark Watson
    Using random items in a slider
    Does anyone know a better way to do the following?
    I am trying to use 3 different random testimonials in a slider but not sure how to get three different random items and render them in the right
    @{ var FirstTestimonial = Model.Content.Site().FirstChild("Testimonial").Children().RandomOrder().FirstOrDefault(); var SecondTestimonial = Model.Content.Site().FirstChild("Testimonial").Children().RandomOrder().FirstOrDefault(); var ThirdTestimonial = Model.Content.Site().FirstChild("Testimonial").Children().RandomOrder().FirstOrDefault();
    @renderTestimonial(FirstTestimonial)
    @renderTestimonial(SecondTestimonial)
    @renderTestimonial(ThirdTestimonial)
    This works but sometimes I get 2 items the same. I would like each testimonial to be different but random.
  • Ronak Panchal 71 posts 230 karma points
    Mar 27, 2019 @ 07:30
    Ronak Panchal
    Hello Mark Watson,
    As per your code, it's true that you get the same items.
    First, take a list of the random item up to 3 then through looping you can display that 3 random items you don't need to take three variable like FirstTestimonial, SecondTestimonial and ThirdTestimonial Just one variable is fine for that.
    Regards, Ronak Panchal
  • Rhys Hamilton 140 posts 942 karma points
    Mar 27, 2019 @ 10:26
    Rhys Hamilton
    As Ronak pointed out, you probably don't need to have three separate variables for this.
    The following code should work:
    var testimonials = Model.Content.Site().FirstChild("Testimonial").Children().RandomOrder().Take(3);
    foreach (var testimonial in testimonials)
        @renderTestimonial(testimonial)
    Mar 27, 2019 @ 22:23
    Mark Watson
    Thanks for the replys but unfortunately the slider is control by script and I need to place the results in the controlling divs. Without the div class "active item" and the following div classes "item" this does not work.
    <div class="carousel-inner">
    <div class="active item">
    <div class="item">
    <div class="item">@renderTestimonial(ThirdTestimonial)
    Mar 28, 2019 @ 10:43
    Rhys Hamilton
    2
    In your code, the first item is active, and the rest are not.
    Using this logic, you could refactor your code, using a single variable (instead of 3) and still produce your expected output by using a counter to determine which items in your testimonials should have the "active" class.
    For example, like so:
        var counter = 1;
            @foreach (var testimonial in testimonials)
                // If the counter is equal to 1, then set the item class to active
                var isActive = counter == 1 ? "active item" : "";
                <div class="@isActive item">
                // Increment the counter, so you can't have two active items at a time
                counter++;
    Mar 28, 2019 @ 12:03
    Nik
    2
    Rhy's solution is nice, but instead of using a counter you could use a Boolean to track if this is the first iteration when using a foreach loop.
    eg:
    var isFirst = true;
        @foreach(var testimonial in testimonials)
               <div class="@(isFirst ? "active item" : "item")">
               if(isFirst){isFirst = false;}
    Personally, I find this easier to read than having a counter that's increment all the time. If you need the counter for something else however then I'd go down that route :-)
    (It comes down to personal preference here I think, just thought it worth sharing the alternative)
    Apr 10, 2019 @ 05:13
    Mark Watson
    Thanks Rhys and Nik
    Both worked perfectly.
