  • Sonja 133 posts 621 karma points
    Mar 29, 2019 @ 10:41
    Sonja
    Changing Related Links
    I have Related Links field in the document type. How do I add an extra field to the related links that will be the querystring? It should be added as a single textbox and after I will concatenate it to the url. Can you give me an example please?
    Mar 29, 2019 @ 10:52
    Alex Skrypnyk
    Hi Sonja
    You can add query string in the Link field, like that:
    Alex
    Mar 29, 2019 @ 10:56
    Sonja
    I know this but if it is internal link than I can't add querystring. So I've been told that it has to be in the new field
    Mar 29, 2019 @ 10:58
    Alex Skrypnyk
    You can use external link for internal nodes :))
    Mar 29, 2019 @ 11:01
    Alex Skrypnyk
    Another way - add some code to the caption field, like [query=temp], then in rendering check this field and move [query=temp] to the url.
    Of course, it's not a perfect solution and you have to be aware on problems with this way of doing this.
    Another way is to create another "Related Link" property editor. Copy the existing one and add a needed field, it's should be easy.
    Alex
    Mar 29, 2019 @ 11:14
    Sonja
    Alex, How do I create another Related Link Property editor? Where do I find existing one?
    Mar 29, 2019 @ 13:12
    Alex Skrypnyk
    Sonja, have a look here:
    \Umbraco\Views\propertyeditors\relatedlinks
    Apr 02, 2019 @ 22:06
    Alex Skrypnyk
    Hi Sonja
    Please, share how did you decide to fix it?
    Alex
    Apr 03, 2019 @ 11:05
    Sonja
    101
    I didn't do changes in the relatedlinks, I have pre-prepared pages with querystrings and internal links and I'm redirecting there
