  • Johannes Lantz 156 posts 840 karma points c-trib
    Apr 05, 2019 @ 06:24
    Johannes Lantz
    Gettins tags without foreach
    Hello all,
    I have been trying now to print all tags without using a foreach loop. But I am not getting the result that I want.
    If I just use Model.Content.GetPropertyValue I get "System.String[]" I have been trying to type it but still getting the same result.
    If I set "EnablePropertyValueConverters" to false, then it works. But I would like to make it work without setting EnablePropertyValueConverters to false.
    Any idés?
    (Using umbraco v 7.14)
  • Jonathan Distenfeld 105 posts 618 karma points
    Apr 07, 2019 @ 16:11
    Jonathan Distenfeld
    Hello Johannes,
    you can use String.Join to display your tags:
    @String.Join(",", propertyvalue)
    You might have to make sure to get the right propertytype first:
    Model.Content.GetPropertyValue<String[]>("youproperty")
    -Jonathan
    Apr 07, 2019 @ 17:54
    Johannes Lantz
    Cheers Jonathan!
    @String.Join(",", Model.Content.GetPropertyValue<String[]>("property"))
    Works like a charm!
