  • DEV 12 posts 102 karma points
    Apr 17, 2019 @ 12:28
    DEV
    Umbraco Upgrade v6.2.6 to v7.0.0 not installing DB
    I am Upgrade to my site Umbraco V6.2.6 to Umbraco v7.0.0. I did all instruction pointed for below url
    https://our.umbraco.com/documentation/getting-started/setup/upgrading/upgrading-to-v7
    During Installation, Data base not install and also display same page long time. Check to my DB configuration in web.config it is fine.
    Why DB not install? .Please Help me
    Regards
    DEV
  • Dave de Moel 122 posts 574 karma points c-trib
    Apr 17, 2019 @ 12:46
    Dave de Moel
    To which version of Umbraco 7 are you trying to upgrade? Try to upgrade to V7.0.0 first as there have been several data changes during the lifetime of Umbraco 7 which might affect the upgrade.
    Apr 17, 2019 @ 12:48
    DEV
    Hi Dave de Moel,
    I am Upgrade to Umbraco V 7.0.0. I am waiting to last 3 hours only display 5%.
    <connectionStrings>
     <remove name="umbracoDbDSN" />
        <add name="umbracoDbDSN" connectionString="Server=Servername;Database=db;User ID=user;Password=pwd;Trusted_Connection=False;" providerName="System.Data.SqlClient" />
    </connectionStrings>
    Regards
    DEV
    Apr 23, 2019 @ 04:06
    DEV
    I found the solution.I am not Putting Connection string in connection.config file.i am using Connection string in web.config file so Database not connected.Now changed to connection.config file.Now it is working fine.
    Regards,
    DEV
