  • Carlos Mosqueda 244 posts 435 karma points
    Apr 17, 2019 @ 18:14
    Carlos Mosqueda
    Umbraco 7.12 having issues setting Publish and Unpublish dates. Getting Moment.js errors
    We have a site running Umbraco 7.12.
    When we try to set the Unpublish date and select a date from the calendar, for some the time will not set and in our console we get a moment.utc(....).utcOffset is not a function error in the Angular. This seems to be in the core of Umbraco.
    Any ideas why this would be causing this issue? My content editors can't set the dates. I even tried as an admin and still having issues.
    Apr 19, 2019 @ 18:17
    Carlos Mosqueda
    ANSWER:
    So we found our issue. We have Diplo Date Range Picker installed in our system. Evidently in the daterangepicker.controller.js file it has a reference to Moment.js, which is an older version of Moment AND core Umbraco uses Moment JS as well. So I switched out the reference in the .load() method in the Angular to point to the Umbraco reference instead.
    This fixed our issue.
