I just tried to access umbraco surface controller from jquery ajax call.
But its not fired, any one please let me know how to call umbraco surface controller via ajax
eg: i have controller called EmployeeSurfaceController, in this i need to invoke getEmployees action method.
If your surface controller is inheriting from UmbracoAuthorizedJsonController, you will not be able to call it using ajax unless you are logged in[or pass credentials]. If you are able to post your surface controller class, it would help in narrowing down the issue.
Call Surface controller from ajax call
I just tried to access umbraco surface controller from jquery ajax call. But its not fired, any one please let me know how to call umbraco surface controller via ajax
Regards, Thomas
Hi Thomas,
this would be an example ajax call:
For more information:
https://www.w3schools.com/jquery/ajax_ajax.asp
https://our.umbraco.com/documentation/reference/routing/surface-controllers
Jonathan
I have used ajax previously to get data from a surfacecontroller.
is
employeesurface==employeesurfacecontrollerin your namespace? Can you post your controller code or an example please?Also make sure the function
getemployeesis public with[HttpGet]access.is working on a reply...
