  • Phil Saint-Gold 5 posts 85 karma points
    May 14, 2019 @ 15:55
    Phil Saint-Gold
    Repeatable HTML blocks
    Hi guys, I use Bootstrap v4 as a web framework, and I would display a HTML component in the backoffice that can be added or deleted dynamically. For example, generate a card
    <div class="card" style="width: 18rem;">
      <img src="..." class="card-img-top" alt="...">
        <div class="card-body">
             <h5 class="card-title">Card title</h5>
             <p class="card-text">Some quick example text to build on the card title and make up the bulk of the card's content.</p>
              <a href="#" class="btn btn-primary">
                   @Umbraco.Field("...")
              </a>
    or any other component.
    It can be done?
    Thanks in advance
    Phil
  • Søren Kottal 713 posts 4571 karma points MVP 7x c-trib
    May 15, 2019 @ 06:28
    May 16, 2019 @ 12:20
    Phil Saint-Gold
    Hi Søren,
    thank you so much, your answer solves the problem!
    Phil
  • Claushingebjerg 939 posts 2574 karma points
    May 16, 2019 @ 12:24
    Claushingebjerg
    Take a look at "stacked content" as well. Its more visual than nested Content.
