  • Łukasz Koruba 30 posts 151 karma points
    May 16, 2019 @ 12:46
    Łukasz Koruba
    Remove External index
    we want to get rid of External index set. When I erase ExternalIndexSet, ExternalIndexer and ExternalSearcher from the Examine configuration I got the following error:
    Unable to load default search provider
    How can I change default search provider or is it even possible?
    Regards
  • Mark Roffey 31 posts 184 karma points
    May 16, 2019 @ 12:52
    Mark Roffey
    I'm not sure you can delete the External Indexset.
    Can I ask why you want to delete it?
    May 17, 2019 @ 07:04
    Łukasz Koruba
    We're not using it at all. Is this a way to change the default search provider?
    May 17, 2019 @ 08:05
    Łukasz Koruba
    102
    Ok, I've found a solution to my problem.
    In the ExamineSettings.config file on ExamineSearchProviders section there is an attribute to set default search provider:
      <ExamineSearchProviders defaultProvider="CustomSearcher">
    Don't know how I missed this but hope it helps if someone will encounter this issue.
  • Marcin Zajkowski 112 posts 585 karma points MVP 7x c-trib
    May 17, 2019 @ 08:07
    Marcin Zajkowski
    Damn, nice finding Łukasz. Didn't know about it too.
