  • Lisa Walsak 9 posts 119 karma points
    May 17, 2019 @ 17:47
    Lisa Walsak
    Nexu not finding Images in Nested Content
    We are evaluating the Nexu package and it seems to work fairly well. However, it didn't find images in Nested Content. Is there a way to do this? It found Nested Content links correctly. Thanks.
  • Daniel Mckibbin 14 posts 106 karma points
    May 23, 2019 @ 16:00
    Daniel Mckibbin
    Following this thread as I'm having the exact same issue at the moment. I also had this issue when using Diplo Godmode.
    Using Umbraco 7.5
    Jun 25, 2019 @ 10:22
    Dave Woestenborghs
    Hi Lisa,
    Just stumbled upon this by accident.
    Normally nexu should find the images used in nested content. What property editor are you using to add the images in Nested content ?
    Dave
    Jun 25, 2019 @ 13:04
    Lisa Walsak
    We are using the Umbraco.MediaPicker2 property editor. Thanks, Lisa
    Jun 25, 2019 @ 14:44
    Dave Woestenborghs
    Hi Lisa,
    Can you also specify which version of Umbraco you are using ?
    And with the nested content. Is it the core one or the legacy package one.
    Dave
    Jun 25, 2019 @ 17:56
    Lisa Walsak
    We are using 7.14.0 and, as far as I can tell, it is the core nested content.
    Jun 25, 2019 @ 20:21
    Daniel Mckibbin
    I would just like to confirm that even using Umbraco's standard media picker in nested content it is not detected. Same with RTE but I didn't expect them to be detected within an RTE.
    We are on 7.5.10
    Jun 26, 2019 @ 06:29
    Dave Woestenborghs
    Hi Lisa and Dan,
    Can you give some more extra information :
    What version of Nexu are you using ?
    Dave
    Jun 27, 2019 @ 15:03
    Lisa Walsak
    Nexu 1.7.1
    We've put this project aside for now. If we go back to it, I'll see if there are any errors in the logs.
    Jun 26, 2019 @ 06:45
    Dave Woestenborghs
    Hi Lisa and Dan,
    I just tested it with the latest version of Nexu on both 7.5.10 and on 7.14
    I can't reproduce the problem. For me the relations are created.
    Could you see if you have any errors in your log when saving a item with the nested content on it.
    Dave
