  • Mitch 44 posts 159 karma points
    May 29, 2019 @ 14:08
    Mitch
    Adding multiple fields with same name to index
    Hi guys
    I've read that Lucene can handle multiple fields with the same name in a document. I've even seen an example using Examine. However, I'm struggling to get it working in 7.14.
    Take this simple code:
    public static void CourseIndexer_DocumentWriting(object sender, Examine.LuceneEngine.DocumentWritingEventArgs e, UmbracoHelper umbHelper)
            var practiceAreas = course.PracticeAreas;
            foreach (var practiceArea in practiceAreas)
                e.Document.Add(new Field("practiceArea", practiceArea, Field.Store.YES, Field.Index.NOT_ANALYZED));
    This only ever adds a single field named "practiceArea". Am I doing something wrong here or is it a bug?
  • Matthew Wise 271 posts 1373 karma points MVP 6x c-trib
    May 30, 2019 @ 08:53
    Matthew Wise
    Hi Mitch,
    You can do this as a space separated terms. You cant have multiple fields with the same name.
    If you terms have spaces just make sure you query with And not or
    Matt
    May 30, 2019 @ 10:03
    Mitch
    Hi Matt
    Thanks for your reply but it is actually possible to do. My code seems to work but I was testing it using the search in the Examine Management tool in the backoffice. In the search results it only seems to display a field once even though several fields with the same name exists, and are searchable. I think this can be classed as a bug.
