  • artem 3 posts 73 karma points
    Jun 05, 2019 @ 19:57
    artem
    ssl problem
    SSL certificate is connected, registered in umbracoUseSSL - true, however, when you go over https protocol, an error "404 - file or directory was not found. The reserve resource has been moved, renamed, or temporarily unavailable. "Version 7.3.7. Admin panel opens at https. What's the problem?
  • Dan Diplo 1554 posts 6205 karma points MVP 6x c-trib
    Jun 06, 2019 @ 08:29
    Dan Diplo
    Checked your bindings? Does this help?
    https://benperk.github.io/msdn/2014/2014-02-http-404-after-installing-an-ssl-certificate.html
    Also check if you have any redirects in web.config within the <rewrite><rules> section and try temporarily disabling them.
    Jun 08, 2019 @ 17:24
    artem
    bindings are:
    Removed all rewrite, the error persists.
    What else could be?
