  • Sonja 133 posts 621 karma points
    Jun 27, 2019 @ 07:00
    Sonja
    when create content, create it for 2 document types at once
    hi
    I have 2 document types: first one is named BasePage and second one PageComponents. Now in Permitions BasePage is Allowed as root and has Allowed Child node types PageComponents.
    How do I make it so when in Content I'm creating BasePage, I create BasePage and PageComponents under it all at one
    please advice
  • Natalie 22 posts 162 karma points
    Jun 27, 2019 @ 07:13
    Natalie
    Hullo,
    I think you can create BasePage and PageComponent in content. And just PageComponent Under BasePage... Unless you don't have the right, you can create all your document type under content and only the ones you decide by setting them up as a child, under the other document types.
    I hope it help...
    Jun 27, 2019 @ 07:30
    Sonja
    Hi, Natalie,
    that's not the point. The requirement is that whenever I create BasePage, the PageComponents should be created automatically under it.
    please advice
    Jun 27, 2019 @ 08:14
    Natalie
    Thing like that : Image
    Meaning my "Accueil" is your BasePage and my "Page" is your PageComponent ?!? When I create My Accueil, I have the Page component avalaible to be created under it. If I create a new Accueil, I could also create page underneath.
    Jun 27, 2019 @ 09:49
    Sonja
    Natalie, All this is already present. However when I create Accuil (my BasePage) automatically one Page (my PageComponent) should be created, that is requirement. 2 creations with 1 step
    Jun 28, 2019 @ 07:11
    Sonja
    Guys, does anybody else have a suggestion? It is possible because I've seen it on USkinned
    Jul 10, 2019 @ 07:52
    Sonja
    I've solved it. needs to override ContentService_Saved where we check if the content service is from the required content type to add another content service as child. This means in Umbraco 8 need to do the following:
    public class MyComposer : IUserComposer
            //composition.SetContentLastChanceFinder<My404ContentFinder>();
            composition.Components().Append<MyComponent>();
    class MyComponent : IComponent
        public void Initialize()
            ContentService.Saved += this.ContentService_Saved;
        public void Terminate()
        private void ContentService_Saved(IContentService sender, SaveEventArgs<IContent> e)
            long totalChildren;
            var contentService = sender;
            var ents = e.SavedEntities.Where(x => x.ContentType.Alias == "myPage");
            foreach (var node in ents)
                if (!contentService.GetPagedChildren(node.Id, 0, 10, out totalChildren).Any(x => x.ContentType.Alias == "ComponentFolder"))
                    var pageComponentsFolder = contentService.CreateContent("Components", node.GetUdi(), "ComponentFolder");
                    contentService.SaveAndPublish(pageComponentsFolder);
