Umbraco 7.7.2 and AzureCDNToolkit exaust my DB connection pool
Hi all, I have a serious issue with Umbraco 7.7.2 and AzureCDNToolkit :
2019-07-07 11:30:31,337 [P14776/D2/T213] ERROR Our.Umbraco.AzureCDNToolkit.UrlHelperRenderExtensions - Error resolving media url from the CDN
System.Net.WebException: The operation has timed out
at System.Net.HttpWebRequest.GetResponse()
at Our.Umbraco.AzureCDNToolkit.UrlHelperRenderExtensions.<>c__DisplayClass6_1.<UrlToCdnUrl>b__0()
at Our.Umbraco.AzureCDNToolkit.UrlHelperRenderExtensions.TryFiveTimes(Action delegateAction)
at Our.Umbraco.AzureCDNToolkit.UrlHelperRenderExtensions.UrlToCdnUrl(String cropUrl, Boolean htmlEncode, String currentDomain)
2019-07-07 11:30:31,978 [P14776/D2/T383] ERROR Our.Umbraco.AzureCDNToolkit.UrlHelperRenderExtensions - Error resolving media url from the CDN
2019-07-07 11:30:31,995 [P14776/D2/T227] ERROR Our.Umbraco.AzureCDNToolkit.UrlHelperRenderExtensions - Error resolving media url from the CDN
2019-07-07 11:30:59,058 [P14776/D2/T257] ERROR Our.Umbraco.AzureCDNToolkit.UrlHelperRenderExtensions - Error resolving media url from the CDN
System.Net.WebException: The underlying connection was closed: An unexpected error occurred on a receive. ---> System.IO.IOException: Unable to read data from the transport connection: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. ---> System.Net.Sockets.SocketException: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond
at System.Net.Sockets.Socket.Receive(Byte[] buffer, Int32 offset, Int32 size, SocketFlags socketFlags)
at System.Net.Sockets.NetworkStream.Read(Byte[] buffer, Int32 offset, Int32 size)
--- End of inner exception stack trace ---
at System.Net.FixedSizeReader.ReadPacket(Byte[] buffer, Int32 offset, Int32 count)
at System.Net.Security._SslStream.StartFrameHeader(Byte[] buffer, Int32 offset, Int32 count, AsyncProtocolRequest asyncRequest)
at System.Net.Security._SslStream.StartReading(Byte[] buffer, Int32 offset, Int32 count, AsyncProtocolRequest asyncRequest)
at System.Net.Security._SslStream.ProcessRead(Byte[] buffer, Int32 offset, Int32 count, AsyncProtocolRequest asyncRequest)
at System.Net.TlsStream.Read(Byte[] buffer, Int32 offset, Int32 size)
at System.Net.PooledStream.Read(Byte[] buffer, Int32 offset, Int32 size)
at System.Net.Connection.SyncRead(HttpWebRequest request, Boolean userRetrievedStream, Boolean probeRead)
This error is recurrent and with TryFiveTimes get my database conection pool exausted and my website gets down.
I'm using Umbraco 7.7.2 with
TryFiveTimesget my database conection pool exausted and my website gets down. I'm using Umbraco 7.7.2 withis working on a reply...
