I have hosted my Umbraco site to two application services in Azure and database also restored to Azure SQL database, both applications can browse and work fine, Could you please let me know that how can I ensure that load balancing environment has been created successfully and working fine, if the environment is working correctly then please guide us that how can we determine (by using the Azure portal) that which application is running as master application and which one is running as secondary application. Any help will be highly appreciated...
Azure load balancing
