Sorry but I'm pretty new to coding and could do with a little pointer.
I'm trying to create a navigation for my website with children, I have the following code but my website doesn't seem to like it and just throws out errors;
Compiler Error Message: CS1061: 'IPublishedContent' does not contain a
definition for 'Any' and no accessible extension method 'Any'
accepting a first argument of type 'IPublishedContent' could be found
(are you missing a using directive or an assembly reference?)
IPublishedContent homePage = Model.Root();
IEnumerable<IPublishedContent> navigationPages = homePage.Children(x => x.IsVisible());
<div data-collapse="medium" data-animation="default" data-duration="400" class="navbar w-nav">
<div class="nav-container w-container">
<nav role="navigation" class="nav-menu w-nav-menu">
@* //The top level requires different rendering to children so let us split it up. *@
@foreach (var topLevelEntry in Model)
//We need to check if this has children or not
if (topLevelEntry.Children != null && topLevelEntry.Children.Any())
<div data-hover="1" data-delay="0" class="drop-down-menu w-dropdown">
<div class="nav-link w-dropdown-toggle">
<a href="@topLevelEntry.Url" class="link-dropdown">
<div>@topLevelEntry.Title</div>
</a>
<nav class="w-dropdown-list">
@RenderChildren(topLevelEntry.Children)
</nav>
else
<a href="@topLevelEntry.Url" class="nav-link w-nav-link">@topLevelEntry.Title</a>
</nav>
<div class="menu-button w-nav-button">
<div class="mobile-icon w-icon-nav-menu"></div>
@helper RenderPageLink(IPublishedContent item)
if (item.Any())
foreach (var item in item)
<a href="@item.Url" class="drop-down-link w-dropdown-link">@item.Title</a>
There are a couple of mistakes in your code and you should fix them.
Let's discuss the RenderPageLink method first. As the error says and Sibren mentioned before, PublishedContent does not contain a definition for any (which is correct, because it's a single item). You can use the .Any method on collections. In this case at most you can add a null check. Your method should look like the code below.
//Check if item not is null
if (item != null)
// Render url for each child page
foreach (var child in item.Children())
<a href="@child.Url" class="drop-down-link w-dropdown-link">@child.Name</a>
Correct me if I'm wrong but I expect that you want to check if a navigation page has children and if so you want to show a link for each of them and if not you want to show the link of the navigation page itself? You can achieve this by doing something like this:
@foreach (var page in navigationPages)
if (page.Children.Any())
<a href="@page.Url" class="link-dropdown">
<div>@page.Name</div>
</a>
@foreach (var child in page.Children())
@RenderPageLink(child)
</nav>
else
<a href="@page.Url" class="nav-link w-nav-link">@page.Name</a>
The full code should look something like this.
</a>
</nav>
else
</nav>
if (item != null)
Render Navigation in umbraco 8
Hi all,
Hi Matt,
I think you're missing the
System.Linqnamespace in your usings? https://docs.microsoft.com/en-us/dotnet/api/system.linq.enumerable.any?view=netframework-4.7.2Btw: your error says IPublishedContent does not contain a definition for any (which is correct, because it's a single item).
Is your model a List
if (topLevelEntry.Children != null && topLevelEntry.Children.Any())This should work once the namespace is added.
Hmm I'm afraid you lost me with the last bit?
I added the namespace although doesn't look like its made a difference or even recognise it....
Morning all,
Anyone able to give me a few pointers to get this code working?
Matt
Hi Matt,
