  • Jasper van den Bergh 4 posts 84 karma points
    Jul 19, 2019 @ 13:10
    Using MemberService in Helper class (Umbraco v8)
    Hi!
    I'm successfully using the Services.MemberService (and other Services) in my Controller classes).
    Like so:
    var member = Services.MemberService.GetByUsername(userName);
    Now I've come to the point that I need a Helper class for some helper methods. In these methods I need access to the MemberService.
    This helper class is preferably a static class.
    I've looked at dependency injection, but haven't found a way to access the Services in a custom class.
    Is it possible?
  • Marc Goodson 2157 posts 14432 karma points MVP 9x c-trib
    Jul 20, 2019 @ 20:15
    Marc Goodson
    101
    Hi Jasper
    Yes it's possible to access services in a custom class using DI, but your service wouldn't be static.
    Using DI:
    (There is some information here that might help: https://our.umbraco.com/documentation/Getting-Started/Code/Umbraco-Services/)
    But essentially create your custom helper service class like so:
    public class JasperHelperService : IJasperHelperService
      private readonly IMemberService _memberService;
            public JasperHelperService(IMediaService memberService)
                _memberService = memberService;
        public string SomeHelperMethod(string userName){
            var member = _memberService.GetByUsername(userName);
            return member.Id;
    You'll need to define an interface for your service
    public interface IJasperHelperService
        public string SomeHelperMethod(string userName);
    Then register your custom service with an IUserComposer
        public class RegisterJasperHelperServiceComposer : IUserComposer
    //Lifetime.Request if it depends on the current request, eg depends context of current member or current published content item, or use Lifetime.Singleton if it's the same context across every request
                composition.Register<IJasperHelperService, JasperHelperService>(Lifetime.Request);
    Now in your controllers you can access your HelperService like so
    public class BlogPostController : Umbraco.Web.Mvc.RenderMvcController
            private readonly IJasperHelperService _jasperHelperService;
            public BlogPostController(IJasperHelperService jasperHelperService)
                _jasperHelperService= jasperHelperService;
            public override ActionResult Index(ContentModel model)
            var memberSomething = _jasperHelperService.SomeHelperMethod("jasper");
    You could access the JasperHelperService in a view by
    IJasperHelperService jasperHelperService = Current.Factory.GetInstance<IJasperHelperService>()
    regards
    Marc
    Jul 22, 2019 @ 11:32
    Thanks Marc, this was really helpful!
