We are getting the below exception every time we run the application the first time
Umbraco.Core.UmbracoApplicationBase - An unhandled exception occurred
System.Configuration.SettingsPropertyNotFoundException: The settings property 'CategoriesRootNode' was not found.
at System.Configuration.SettingsBase.GetPropertyValueByName(String propertyName)
at System.Configuration.SettingsBase.get_Item(String propertyName)
at System.Configuration.ApplicationSettingsBase.GetPropertyValue(String propertyName)
at System.Configuration.ApplicationSettingsBase.get_Item(String propertyName)
at PacDig.Atlantic.Cms.Properties.Settings.get_CategoriesRootNode()
at PacDig.Atlantic.Services.Content.CategoryContentService.AddToCache()
at PacDig.Atlantic.Services.Content.ContentMasterDetails.Populate(IContentMaster content, Int32 relatedContentCount, String categoryQueryString, String path, Boolean canHaveCategorySponsorship)
at PacDig.Atlantic.Services.Controllers.Handlers.ArticleControllerCommandHandler.Index(IPublishedContent content, Int32 relatedContentCount, String categoryQueryString, String path)
at PacDig.Atlantic.Cms.Controllers.ArticlePageController.Index(RenderModel model)
at lambda_method(Closure , ControllerBase , Object[] )
The missing property 'categoriesrootnode' is already there in settings.cs
We are not sure why this exception is occuring.
Any help appreciated
