  • Haris Tasawar 3 posts 73 karma points
    Aug 15, 2019 @ 06:42
    Haris Tasawar
    Route Hijacking Issue
    Hi all,
    As i am fairly new to Umbraco, i seem to be having issues regarding route hijacking. I keep getting the below error when i am trying to achieve this:
    Cannot bind source type Umbraco.Web.Models.ContentModel to model type Test.Company.
    So, below are the details regarding my code:
    Model(Company.cs):
       public partial class Company
    {  //  public int CompanyID { get; set; }
        public string CompanyNameEnglish { get; set; }}
    Controller(companyDashboardController.cs):
    public class companyDashboardController : RenderMvcController
        public ActionResult CompanyNavRender()
            Company model = new Company();
            return PartialView("CompanyNavBar", model);
        [HttpPost]
        public ActionResult Companydashboardload(string Compname)
            TestEntities db = new TestEntities();
            string username = System.Web.HttpContext.Current.Session["UserName"].ToString();
            var obj = db.Companies.Where(a => a.CompanyNameEnglish.Equals(Compname));
            if (obj != null)
                return View("~/Views/companyDashboard.cshtml", obj);
                // Session["UserID"] = obj.RegistrationID.ToString();
                // Session["UserName"] = obj.UserName.ToString();
                // in//t thankYouPageId = Int32.Parse(CurrentPage.GetProperty("taxify-registration"));
                //return RedirectToUmbracoPage(1168);
                // return RedirectToUmbracoPage("/test-registration");
    My View(companyDashboard.cshtml):
    @inherits Umbraco.Web.Mvc.UmbracoViewPage<Company>
     Layout = null;
       <section class="page_toplogo ls c-my-15 breadcrumbs">
                <div class="container-fluid">
                    <div class="row align-items-center">
                        <div class="col-lg-4 text-center text-lg-left">
                            @*<a href="./" class="logo text-center">
                <img src="~/images/logo-dark.png" alt="">
            </a>*@
                        @Html.Action("CompanyNavRender", "companyDashboard");
            </section>
    I have included the part which i think is causing the error to be generated.
    Also, i have a document type of the same name (i.e companyDashboard) in Umbraco as well.
    Can anyone please help me with this issue?
    Thanks, Harry.
  • Shaishav Karnani from digitallymedia.com 354 posts 1638 karma points
    Aug 16, 2019 @ 06:51
    You need to first general class using model builder. It will generate class companyDashboard.cs
    public class CompanyDashboardController : Umbraco.Web.Mvc.RenderMvcController { public override ActionResult Index(ContentModel model) { // Do some stuff here, then return the base method // model.Content will have iPublishedContent from companyDashboard return base.Index(model); } }
    Aug 18, 2019 @ 10:22
    Haris Tasawar
    Hi Digitally,
    Thanks for the tip but i am actually not using the model builder , i am not sure if it`s support on V8 of umbraco, i am actually using Entity Framework for MVC so i am not sure if i can use the model builder package to do this? is it possible to use both for my Application?
    Thanks, Harry.
