  • Patrick Davis 3 posts 73 karma points
    Aug 27, 2019 @ 11:34
    Patrick Davis
    Trouble with MultiUrlPicker
    I am having some trouble using the core URL picker. I followed the documentation exactly but my model is always null.
    Here's the relevant cshtml from my _Footer partial, which is rendered by a site layout controller in my master template.
    _Footer.cshtml
    @inherits  UmbracoViewPage
    @using Umbraco.Web.Models
    IEnumerable<Link> footerLinks = Model.Value<IEnumerable<Link>>
    ("footerLinks", fallback: Fallback.ToAncestors);
    <footer id="footer">
    <div class="inner">
        <div class="content">
            <section>
                <h4 style="text-align:center">Networks</h4>
                <hr />
              if (footerLinks.Any())
                <ul class="plain">
                    @foreach (var link in footerLinks)
                        <li><a href="@link.Url"
              target="@link.Target">@link.Name</a></li>
                </ul>
            </section>
    Controller
      public ActionResult RenderFooter()
            return PartialView(PARTIAL_VIEW_FOLDER_PATH + "_Footer.cshtml");
    Master
    <!-- Footer -->
    @{ Html.RenderAction("RenderFooter", "SiteLayout");}
    Error
    Description: An unhandled exception occurred during the execution of
    the current web request. Please review the stack trace for more
    information about the error and where it originated in the code.
    Exception Details: System.NullReferenceException: Object reference not
    Source Error:
     Line 3:  @using Umbraco.Web.Models
     Line 4:  @{
     **Line 5:  IEnumerable<Link> footerLinks = Model.Value<IEnumerable<Link>>
      ("footerLinks",
     fallback: Fallback.ToAncestors);**
     Line 6:  }
     Line 7:  <footer id="footer">
    CMS doc type
    Any help would be really appreciated.
  • Shaishav Karnani from digitallymedia.com 354 posts 1638 karma points
    Aug 27, 2019 @ 13:09
    Hi Patrick,
    Is your footerLinks on the same page that you are trying to access. I think it could be one level up and so you need to add below code.
    Model.Value<IEnumerable<Link>>("footerLinks", fallback: Fallback.ToAncestors);
    Aug 27, 2019 @ 14:23
    Patrick Davis
    Hi Shaishav,
    Unfortunately, this was not the solution. I really appreciate the input though. The footer is for global use, not page by page basis. If it helps, I'll attach a picture of my structure. Folder Structure
    Aug 27, 2019 @ 14:54
    Patrick Davis
    Fix:
    The guide doesn't account for different setups, what has confused me is the use of a model when this isn't a custom model. In fact, I was able to access it with this instead:
       IEnumerable<Link> footerLinks = Umbraco.AssignedContentItem.Value<IEnumerable<Link>>("footerLinks", fallback: Fallback.ToAncestors);
