  • Laurent Lequenne 123 posts 248 karma points
    Sep 03, 2019 @ 13:02
    Laurent Lequenne
    Umbraco 8 and document picker with XPath
    Did anyone experimented some troubles with the Xpath Query in a multinode picker with umbraco 8.1.
    For instance $root/someType works fine but adding more nesting doesn't work anymore. Which is not that convenient ?
  • Shaishav Karnani from digitallymedia.com 354 posts 1638 karma points
    Sep 03, 2019 @ 14:39
    Hi Laurent,
    We faced this issue and instead of $root we used $website and all worked fine.
    Please can you try using $website and let us know how it goes for you.
    Regards,
    Shaishav
    Sep 11, 2019 @ 06:31
    Laurent Lequenne
    It seems to be $site :-) I did a quick test and it seems to work, but I don't see really the point that it works only partially with $root.
    Sep 26, 2019 @ 21:32
    Laurent Lequenne
    This is fixed in 8.1.5
