  • Rasmus Olofsson 23 posts 187 karma points c-trib
    Sep 09, 2019 @ 14:57
    Rasmus Olofsson
    Possible to make inherited composition property required?
    Umbraco CMS version 7.13
    Problem: I have a composition document type with a property that is optional. A document type which inherits this composition needs the property to be required.
    Is this possible to do? Or is there a fairly simple workaround? If I create the property again in the document type that inherits, there will be an exception thrown I believe.
  • Shaishav Karnani from digitallymedia.com 354 posts 1638 karma points
    Sep 09, 2019 @ 15:15
    Hi Rasmus,
    This is not possible. Inherited composition property cannot be altered.
    Shaishav
    Sep 11, 2019 @ 14:09
    Rasmus Olofsson
    Thank you for the quick answer!
