For Blazor to run, you need .NET Core. Umbraco v9 is supposed to work with .NET Core. If that is the case then it would technically be possible to use Blazor for some of the backoffice screens. However I don't think it will happen. It is too big an undertaking, to rewrite the whole of the backoffice. It still uses AngularJS 1.7x. If anything, I can see them upgrading to use a newer version of Angular, but not to use Blazor.
I know that sometime Umbraco will have to migrate to .NET Core. Since in the future .NET 5 will be the Core. As for backoffice migrating from 1.7.x to a recent version of Angular, wouldn't that be the same as rewriting? I worked a little with new versions of Angular, but as far as I know it's very different from version 1.7.x
My friend Jamie Taylor from The dotnet Core podcast did a talk at the Umbraco UK Festival last year and he created this GitHub repo for it where he got blazor working with Umbraco headless
Umbraco and Blazor?
Will any future versions of Umbraco support Blazor? Should I be learning it or at least be aware of it for my future Umbraco sites?
Hi Connie
Cheers
Paul
Go learn it!
If you dont use it on an umbraco project, you can use it on something else.
Also, it never hurts to learn something, just for the sake of learning.
https://github.com/GaProgMan/UmBlazor
@Paul: thank you for the info about Jamie Taylor and his talk.
I find the combination of Umbraco (headless) and Blazor totally interesting. Jamie just gave me some links:
Jamie Taylor Umbraco talk: GitHub repo with Slides
Jamie Taylor Umbraco talk: Youtube Video
dotnetcore Podcast of the talk
