  • Connie DeCinko 95 posts 248 karma points
    Sep 20, 2019 @ 21:35
    Connie DeCinko
    Example Umbraco Headrest Project
    Is anyone aware of a sample project showing how to use Umbraco Headrest? I'm trying to see how it wires up to the actual content. Anyone know how I can reach out to Matt Brailsford?
  • Qaisar 31 posts 77 karma points
    Oct 02, 2019 @ 09:48
    Qaisar
    Try looking into this project from Matt its using headrest
    https://github.com/mattbrailsford/nullorwhitespace-backend
    Oct 02, 2019 @ 17:31
    Connie DeCinko
    Can I have a hybrid solution with HeadRest? Display content as Umbraco normally would, AND be able to retrieve that content via API?
  • Shola 65 posts 273 karma points
    Apr 26, 2020 @ 15:00
    Shola
    Looks like the answer is yes. See the "Supports mixed install" row on this page:
    https://github.com/mattbrailsford/umbraco-headrest#how-is-headrest-different-to-umbraco-headless
  • Bidya Bhusan Hota 1 post 71 karma points
    Jul 01, 2021 @ 08:25
    Bidya Bhusan Hota
    Hi Matt @mattbrailsford,
    As I followed the "Advanced Configuration" section mentioned in https://github.com/mattbrailsford/umbraco-headrest, I get the message "This document is published but its url cannot be routed" for the node item in Umbraco Links. And I'm not able to load the corresponding page as the routing is impacted. Am I doing anything wrong?
    Also I referred the git repo https://github.com/mattbrailsford/nullorwhitespace-backend to implement the same in my Application.
