  • nickornotto 403 posts 907 karma points
    Sep 24, 2019 @ 21:31
    nickornotto
    After upgrade to 7.15.1 tags went crazy
    After the upgrade to 7.15.1 the tags in my backoffice look like this:
    I am unable to delete them. And I am unable to add any new tags in.
  • Shaishav Karnani from digitallymedia.com 354 posts 1638 karma points
    Sep 25, 2019 @ 05:18
    Hi Manila,
    I would suggest that you change the Tags Property to Label and see how the data is being stored in the first place after upgrade. You have couple of options:-
    1. Create a new property (tagsNew) and remove this property (tags). Or
    2. Once you turn it into label you will be able to see how data is stored and if you can upgrade the data with new tags storage approach.
    Hope it helps to solve your issue.
    Shaishav
  • Steve Megson 151 posts 1024 karma points MVP c-trib
    Sep 25, 2019 @ 06:35
    Steve Megson
    7.12 changed the default storage for tags from CSV to JSON. The upgrade should have set the storage type on existing data types to CSV so that they continued to work, but it seems that in some cases this hasn't worked. This weirdness is what happens when the tags editor was expecting JSON but found CSV in the database.
    Changing your data type's setting back to CSV should fix the problem.
    Sep 27, 2019 @ 16:55
    nickornotto
    My tgs are still written as delimited strings.
    Changing the Tags type to CSV worked. Thanks
