    Sep 26, 2019 @ 12:25
    Ismail Mayat
    How to create custom index in v8
    In v7 to create custom index you had to implement ISimpleDataService interface and over ride getdata. In 8 looking at https://our.umbraco.com/Documentation/Reference/Searching/Examine/indexing/ this seems to be for Umbraco content index.
    Looking at examine source with webdemo for custom non umbraco content seems like in startup you create index. Then create controller to rebuild the index with your data source see https://github.com/Shazwazza/Examine/blob/master/src/Examine.Web.Demo/Global.asax.cs
    Or am i reading this wrong? Has anyone already done this?
    Regards
    Ismial
  • Mark Bowser 273 posts 860 karma points c-trib
    Sep 26, 2019 @ 14:51
    Mark Bowser
    I believe you need to create an IndexPopulator for your index. Make sure to implement the PopulateIndexes method. I'm pulling this pretty much directly from the v8 bridging course for searching and indexing, but I haven't put it into practice outside of that training yet. Let me know if this does the trick:
    The IndexPopulator
    public class TodoIndexPopulator : IndexPopulator
        private readonly TodoValueSetBuilder _todoValueSetBuilder;
        public TodoIndexPopulator(TodoValueSetBuilder productValueSetBuilder)
            _todoValueSetBuilder = productValueSetBuilder;
            RegisterIndex("TodoIndex");
        protected override void PopulateIndexes(IReadOnlyList<IIndex> indexes)
            using (var httpClient = new WebClient())
                var jsonData = httpClient.DownloadString("https://jsonplaceholder.typicode.com/todos/");
                var data = JsonConvert.DeserializeObject<IEnumerable<ToDoModel>>(jsonData);
                if (data != null)
                    foreach(var item in indexes)
                        item.IndexItems(_todoValueSetBuilder.GetValueSets(data.ToArray()));
    This IValueSetBuilder
    public class TodoValueSetBuilder : IValueSetBuilder<ToDoModel>
        public IEnumerable<ValueSet> GetValueSets(params ToDoModel[] data)
            foreach (var todo in data)
                var indexValues = new Dictionary<string, object>
                    ["userId"] = todo.UserId,
                    ["id"] = todo.Id,
                    ["title"] = todo.Title,
                    ["completed"] = todo.Completed
                var valueSet = new ValueSet(todo.Id.ToString(), "todo", indexValues);
                yield return valueSet;
    Composer
    public class ExamineComposerPublic : IUserComposer
            //Add our component
            composition.Components().Append<ExamineComponents>();
            composition.RegisterUnique<TodoValueSetBuilder>();
            composition.Register<TodoIndexPopulator>(Lifetime.Singleton);
            composition.RegisterUnique<TodoIndexCreator>();
    Sep 26, 2019 @ 15:16
    Ismail Mayat
    Cool, many thanks for this. I did ask the other day on umbraco slack if bridging course had been done by anyone lol.
    Im hoping to get on it soon.
    Regards
    Ismail
    Sep 26, 2019 @ 15:49
    Ismail Mayat
    Whats in ExamineComponents and TodoIndexCreator ?
    Sep 26, 2019 @ 16:27
    Sep 26, 2019 @ 16:34
    Mark Bowser
    Take the rest of this as a starting point. It is also basically copy pasted from the v8 bridging course, but I think started messing with it and don't know what state I left it in.
    IndexCreator
    The IndexCreator is a LuceneIndexCreator. It returns an IEnumerable
    public class TodoIndexCreator : LuceneIndexCreator
        private ILogger ProfilingLogger { get; }
        public TodoIndexCreator(ILogger profilingLogger)
            ProfilingLogger = profilingLogger;
        public override IEnumerable<IIndex> Create()
            var index = new TodoExamineIndex("TodoIndex",
                CreateFileSystemLuceneDirectory("TodoIndex"),
                new FieldDefinitionCollection(
                new FieldDefinition("userId", FieldDefinitionTypes.Integer),
                new FieldDefinition("id", FieldDefinitionTypes.Integer),
                new FieldDefinition("title", FieldDefinitionTypes.FullTextSortable),
                new FieldDefinition("completed", FieldDefinitionTypes.FullTextSortable)),
                new StandardAnalyzer(Lucene.Net.Util.Version.LUCENE_30),
                null,
                null,
                ProfilingLogger);
            return new[] { index };
    IndexComponent
    The IndexComponent in the example I posted is where all the custom indexing logic happens. In the bridging course, it adds the todo index to the ExamineManager's list of indexes, and combines all of the fields into one aggregated field that users can search on. I won't post the whole thing, but I'll add some snippets here:
    Add index to Examine Manager
    foreach (var data in _todoIndexCreator.Create())
        _examineManager.AddIndex(data);
    Attach to IndexProviderTransformingIndexValues to make aggregate field
        //we need to cast because BaseIndexProvider contains the TransformingIndexValues event
        if (!(index is BaseIndexProvider indexProvider))
            throw new InvalidOperationException("Could not cast");
        indexProvider.TransformingIndexValues += IndexProviderTransformingIndexValues;
    /// <summary>
    /// Combine all fields into single aggregate field
    /// </summary>
    /// <param name="sender"></param>
    /// <param name="e"></param>
    private void IndexProviderTransformingIndexValues(object sender, IndexingItemEventArgs e)
        //this is the replacement for the GatheringNodeData
        if (e.ValueSet.Category == IndexTypes.Content)
            try
                var combinedFields = new StringBuilder();
                foreach (var fieldValues in e.ValueSet.Values)
                    foreach (var value in fieldValues.Value)
                        if (value != null)
                            combinedFields.AppendLine(value.ToString());
                e.ValueSet.Add("contents", combinedFields.ToString());
            catch (Exception ex)
                _logger.Error<ExamineComponents>(ex, "Error combining fields for {ValueSetId}", e.ValueSet.Id);
    Attach to DocumentWriting to do some boosting
        if (!(index is LuceneIndex luceneIndex))
        luceneIndex.DocumentWriting += LuceneIndex_DocumentWriting;
    private void LuceneIndex_DocumentWriting(object sender, global::Examine.LuceneEngine.DocumentWritingEventArgs e)
        //if its blog item and the blog tag is set to cheese boost it else set it to 1
        var nodeTypeAlias = e.ValueSet.ItemType;
        if (nodeTypeAlias?.ToString() == "blogpost")
            var newsTag = e.ValueSet.GetValue("categories");
            if (newsTag != null && newsTag.ToString().InvariantContains("cheese"))
                e.Document.Boost = 1000;
            else
                e.Document.Boost = 1; //may have been set to cheese before and now been changed
