  • Johannes Lantz 156 posts 840 karma points c-trib
    Sep 26, 2019 @ 18:31
    Johannes Lantz
    Package and CustomApplicationEventHandler
    Hello everyone!
    So I am creating a package using the CustomApplicationEventHandler.
    It basically listen to a node and preforms an action when a specified node is saved.
    If I am not wrong, the namespace needs to be the same as the rest of the project in order to work. Am a bit unsure on how to proceed with this. Anyone got an suggestion, link or something to guide me in the right direction ?
    Thanks!
    //Johannes
  • Shaishav Karnani from digitallymedia.com 354 posts 1638 karma points
    Sep 27, 2019 @ 07:25
    Hi Johannes,
    This is good article on Package creation. https://24days.in/umbraco-cms/2017/creating-and-publishing-a-package/
    Are you able to run the Package in your current website as normal? If you can then you can choose the files and dll and built the package as per above link.
    Shaishav
    Nov 25, 2019 @ 08:08
    Johannes Lantz
    Hi Shaishav!
    Thank you for your reply! Works like a charm now!
    // Johannes
