  • bronzewind 42 posts 125 karma points
    Sep 26, 2019 @ 20:28
    bronzewind
    Setting up multitenancy doesn't works
    Hi all,
    I'm trying to set up 2 websites in only one instance of Umbraco. In order to do this, I followed the instructions about creating a doc type that will hold the settings and created another 2 doc types, one for each site and allowed the settings doc type to be a child of each one of the websites basic doc type.
    Now I have to set the useDomainPrefixes to true. When I do so and run the application, it looses the path for Umbraco.Core.pdb. If I take out this key, then everything goes back to normal.
    Any ideas on what can I do to make multitenancy work in V8? Thanks!
  • Shaishav Karnani from digitallymedia.com 354 posts 1638 karma points
    Sep 30, 2019 @ 06:20
    Hi Bronze,
    Functionality for One Umbraco Instance to Host Multiple Sites has not changed. So, this work same as earlier.
    Have you assigned domain names as shown in the Step 4 of below links.
    This link is useful. https://www.spacebetween.co.uk/blog/journal-of-a-junior-using-one-umbraco-instance-to
    Hope it helped to solve the issue.
    Shaishav
    Oct 02, 2019 @ 19:46
    bronzewind
    Hi Shai,
    I was able to solve it by reinstalling Umbraco. Looks like something wasn't right there. But for others that read this post it is important to say that yes your link is the solution so if something else looks weird (like my issue) now you know how I solved it.
    Thanks so much!
  • Jan Hansen 20 posts 50 karma points
    Jun 23, 2020 @ 11:05
    Jan Hansen
    The solution doesn't seem to work in Umbraco v8.
    useDomainPrefixes causes a YSOD when added to umbracoSettings.config.
    Jun 23, 2020 @ 13:15
    bronzewind
    It does work. What issues are you having?
    Jun 23, 2020 @ 13:21
    Jan Hansen
    I get af YSOD when I add the setting...
