The drag and drop sort function works well for short lists of nodes however there are some problems with long lists once the scroll bar appears.
When you have 100 nodes to sort for example, the drag and drop feature only allows you to drag up to the top of the viewable area, you then then need to drop the selected node and scroll up to then repeat the process.
If the user were able to keep the node selected whilst scrolling it up this will save time with longer lists. Possibly allow click to select and allow use of arrow keys to move it up and down too?
Umbraco V7.14.0 - Improve the drag and drop sort function for nodes
