  • Paul Griffiths 370 posts 1021 karma points
    Sep 30, 2019 @ 17:44
    Paul Griffiths
    Strongly typing in v8 Custom Controller
    Following the official documentation at https://our.umbraco.com/documentation/reference/routing/custom-controllers I am attempting to build a custom controller which returns a custom view model.
    Here is my view model
    public class HomePageViewModel : ContentModel
        public HomePageViewModel(IPublishedContent content) : base(content)
        public string Heading { get; set; }
    and here is my controller
            public override ActionResult Index(ContentModel model)
            var vm = new HomePageViewModel(model.Content)
                Heading = model.Content.Value<string>("heading")
            return CurrentTemplate(vm);
    This works as expected but i was wondering whether it is possible to make the contentModel into the type of the model generated by models builder so instead of using model.Content.Value
    I know in v7 when looping through children you could cast to the model type but i was wondering if its possible in the scenario ? I attempted to implement by casting using the bottom suggestion in this post https://stackoverflow.com/questions/34324608/umbraco-cast-ipublishedcontent-type-to-custommodel-type
    I have a core project and .web project. I have used the models builder tool to generate the models into my .core project which is where my controller resides.
    Is the model.Content.Value
    TIA
    Sep 30, 2019 @ 19:36
    Nik
    2
    Hi Paul,
    Yes it is possible.
        //This should do the job :-)
        var typedModel = model.Content as Umbraco.Web.PublishedModels.Home;
    Nik
    Oct 01, 2019 @ 06:35
    Paul Griffiths
    Good morning Nik,
    Thanks for the reply! I was using the same code as you provided last night but was using model instead of .content :|. Tired mind!
    Do you know whether this strongly typed approach is standard practice i.e. would you expect developers to cast this or would you expect to see model.Content.Value
    I prefer the strongly typed approach but i also want to be following best practices.
    Thanks Paul
