    Oct 02, 2019 @ 10:15
    Ismail Mayat
    Composer does not have parameterless constructor
    I have getting the following error when composing:
    Composer Site.Core.Composers.TagComposition does not have a parameter-less constructor.
    The code looks like:
    [ComposeAfter(typeof(BaseCompositions))]
    public class TagComposition:IUserComposer
        private readonly ITagService _tagService;
        public TagComposition(ITagService tagService)
            _tagService = tagService;
    I need to inject in that tagservice which was registered in BaseCompositions : I am doing it wrong I guess. Bascially in this composer I am trying todo:
            ExamineManager.Instance.TryGetIndex(HiqhQIndexConstants.ExamineIndexName, out var highQIndex);
            highQIndex.IndexOperationComplete += HighIndexingComplete;
    In the HighIndexingComplete method I use tag service.
    What is the correct way todo this?
  • Nik 1625 posts 7295 karma points MVP 8x c-trib
    Oct 02, 2019 @ 10:20
    Nik
    Hey Ismail,
    I don't think Composers can have things injected into them. This is why we use Components and the Composer is there to register the component.
    If you look at my post here: https://www.justnik.me/blog/indexing-sort-able-dates-in-umbraco-version-8 I'm interacting with indexing events, granted not the same event you are, but if you do it within a Component you can use DI to get the services etc you need :-)
    Nik
    Oct 02, 2019 @ 11:06
    Ismail Mayat
    So I have updated things but now get
    Boot failed: Umbraco cannot run. See Umbraco's log file for more details.
    -> Umbraco.Core.Exceptions.BootFailedException: Boot failed.
    -> System.NullReferenceException: Object reference not set to an instance of an object. at Umbraco.Web.Runtime.WebInitialComposer.<>c.
    I have
    public class BaseCompositions : IUserComposer
            RegisterServices(composition);
            RegisterComponents(composition);
    in register services i register my tag service. I then register component:
            private void RegisterComponents(Composition composition)
            composition.Components().Append<HighQTagComponent>();
    and that component looks like:
        public class HighQTagComponent:IComponent
        public HighQTagComponent(ITagService tagService)
    Still missing something I think?
    Oct 02, 2019 @ 11:45
    Ismail Mayat
    So playing with this a bit more:
    My tagservice has constructor:
            public HighQTagService(ITagRepository tagRepository,ITagQuery tagQuery)
            _tagRepository = tagRepository;
            _tagQuery = tagQuery;
    The 2 items i am injecting in belong in:
    using Umbraco.Core.Persistence.Repositories;
    using Umbraco.Web;
    when i take those out the constructor everything boots up. I took out ITagQuery and it boots. Looks like it does not like me injecting ITagQuery in.
    Anyone any ideas?
    Regards
    Ismail
  • Dave Woestenborghs 3504 posts 12135 karma points MVP 10x admin c-trib
    Oct 02, 2019 @ 12:24
    Dave Woestenborghs
    Hi Ismail.
    ITagRepository and ITagQuery are Umbraco core things, right ?
    Maybe core is not set up to use them in DI ?
    Edit : Can you try to inject them in a controller just to check ?
    Dave
    Oct 02, 2019 @ 12:37
    Ismail Mayat
    according to this it should work https://our.umbraco.com/Documentation/Reference/Cache/examples/tags
    the ITagQuery one is the problem the repo one injects fine.
    Oct 02, 2019 @ 12:26
    Nik
    @Dave: ITagQuery is set up as DI https://github.com/umbraco/Umbraco-CMS/blob/8b7418164d112e7247e901f18c486ff37e1fa611/src/Umbraco.Web/Runtime/WebInitialComposer.cs#L104
    It's also injected in the UmbracoHelper class in core.
    @Ismail, how are you registering your service? I'm wondering if it's throwing an issue because ITagQuery is registered as having a lifetime of Request
    Nik
    Oct 02, 2019 @ 12:27
    Nik
    Also, does it work if you remove:
    Nik
    Oct 02, 2019 @ 12:36
    Ismail Mayat
    Nik,
    I was registering as singleton changed it to request still no joy. I also removed Runtime level attribute still no joy.
    Oct 02, 2019 @ 13:00
    Nik
    It might be that you can't use the ITagQuery within a component, Umbraco is at too low a level when this is working, and so the web request bits that it relies on aren't established (just a guess) but it works if you are injecting the services into a controller but not if you are injecting the service into a component constructor.
  • Kevin Jump 2348 posts 14896 karma points MVP 9x c-trib
    Oct 02, 2019 @ 13:42
    Kevin Jump
    HI
    I think it might be because it's circular.?
    The core TagQuery class constructor requires ITagService.
    public TagQuery(ITagService tagService, IPublishedContentQuery contentQuery, UmbracoMapper mapper)
    So when it tries to resolve the ITagService for TagQuery in the service it can't because the service isn't there.
    I think if you want to implement your own ITagService you can't use ITagQuery within it.
    The core ITagService goes to the DB for all of it's tags, maybe you could inherit that as a base class and intercept the bit you need?
    UPDATE: No It might be a bit more complicated that that :( - I can't get it to register in any service
    Oct 02, 2019 @ 13:59
    Kevin Jump
    I think you can only use the ITagQuery within a request.
    so if you register your service to havea lifetime of request
    public class MyTagService
        public MyTagService(ITagQuery tagQuery)
    composed :
    composition.Register<MyTagService>(Lifetime.Request);
    then this will register and can be injected into a controller for example but if you try to use the service in a component it will blow up.
    I think this is because ITagQuery has a lifetime of Request, and requires IPublishedContentQuery which i think reliies on an Umbraco Context which you don't have during the startup in a component.
    Oct 02, 2019 @ 14:08
    Ismail Mayat
    Cool,
    Makes sense although while on the bog i just figured out the method i need in that service calls a method on the IRepo which i can inject so i can just use that lol.
    Many thanks for your help guys.
    Oct 02, 2019 @ 14:12
    Kevin Jump
    lol but TMI :)
