I'm creating a custom section in Umbraco V8 for an export plugin.
Now I want to generate an export when creating the export button in the footer of the section, this works but when I click on the export button, I want to change the state to busy so that the user can't click it again and it is visible that Umbraco is working.
Thanks! I need a button group because there are some more options available later, for example download latest export. Though this helped because I implemented the export in the button group object and call it from there.
Button state busy custom Section
I'm creating a custom section in Umbraco V8 for an export plugin. Now I want to generate an export when creating the export button in the footer of the section, this works but when I click on the export button, I want to change the state to busy so that the user can't click it again and it is visible that Umbraco is working.
I created the button using the following documentation: https://our.umbraco.com/apidocs/v8/ui/#/api/umbraco.directives.directive:umbButtonGroup
Though I'm not sure how to call the button and change the state from the handler and from another angular function.
You can use the
umb-buttondirective in case you don't need a group.And for the controller:
