  • Mus'ab 158 posts 387 karma points notactivated
    Oct 06, 2019 @ 07:00
    Mus'ab
    what is the best practicing for views counter and likes counter for pages ?
    Hi our
    i am working on news website and i want to make a views counter and like button for the news witch is the best way to do it referring to that i have a huge number of nodes.
  • Mila Pandurska 75 posts 354 karma points
    Oct 08, 2019 @ 11:09
    Mila Pandurska
    Hi Mus'ab, the proper way tohandle view counter, likes, ratings and so on is to use POCO objects which will store the data in custom db table. You can get the idea here: https://creativewebspecialist.co.uk/2013/07/16/umbraco-petapoco-to-store-blog-comments/
    Mila
    Oct 10, 2019 @ 08:26
    Mus'ab
    Hi Mila
    i think that this article using umbraco 7 and there are a many changes in umbraco 8 do you have any idea about this ?
  • Nik 1625 posts 7295 karma points MVP 8x c-trib
    Oct 10, 2019 @ 08:32
    Nik
    Hi Mus'ab
    https://our.umbraco.com/documentation/Extending/Database/ << This is a good intro into extended the database in Umbraco v8. It uses Migrations to deploy schema changes so you can track the state of your modifications in different environments should the need arise.
    Nik
    Oct 10, 2019 @ 10:20
    Mus'ab
    Hi Nik
    Thank you for your help i can create the table now but how can i insert and edit rows in the table that i created from the views ?
