    Oct 07, 2019 @ 08:19
    Ismail Mayat
    v8 index rebuild issue
    I have a v8 extranet site, if index folders in app_data are deleted then site restarted then all 3 indexes do not fully rebuild. After load if you rebuild through backoffice everything rebuilds fine.
    I have checked through logs and no errors. I should get 200 documents in the external index however i only get about 39. Weird thing is when i look in luke i see that quite a few of those items are deleted, if in luke i optimise index it removes those.
    This only seems to happen with this one site. Not sure why its really weird.
    Anyone seen this before?
  • Yakov Lebski 594 posts 2350 karma points
    Oct 08, 2019 @ 02:08
    Yakov Lebski
    Do you have attached to Gathering Data event on this index?
    Oct 08, 2019 @ 06:52
    Ismail Mayat
    This is v8 site so no gatheringnode we are doing some document writing however even when i take that out it still does the same thing.
    I fiddled with ignoring Folder types from the media section and I get nothing in the index. It seems as though on startup the only thing it can get to its folders in the media section.
