  • Christina 127 posts 390 karma points notactivated
    Oct 15, 2019 @ 15:26
    Christina
    Slimsy not generate webp format
    Hi i use slimsy with razor helper https://github.com/Jeavon/Slimsy/blob/dev-v3/TestSite/App_Code/SlimsyHelper.cshtml and in v7 the images were generated as wbp format but in v8 they are generated as jpg. Does anyone have an idea? I tested the latest version of slimsy 3.0.0-beta3. Ihave also tried the solution but It doesn't work either
    / Christina
  • Daniel 29 posts 142 karma points
    Jan 17, 2020 @ 19:18
    Daniel
    Hi Christina, I had the same issue inv8, and found out that the package ImageProcessor.Plugins.WebP was missing. So you have to run "install-package ImageProcessor.Plugins.WebP" on your project, and the images will appear then WebP. I created an issue on Github ( https://github.com/Jeavon/Slimsy/issues/23 ) regarding the same. Cheers, Daniel
    Jan 28, 2020 @ 09:42
    Christina
    Hi Daniel
    Many thanks :) you solved my problem
    /Christina
