  • Adriano Fabri 469 posts 1633 karma points
    Oct 16, 2019 @ 14:06
    Adriano Fabri
    How to sort search result with a custom index
    Hi, I need to order search result by a date field (desc).
    This is my custom Examine Index file (with Component, Composer and IndexCreator classes):
    /// <summary>
    /// AF Examine Index Creator
    /// </summary>
    public class AFExamineIndexCreator : LuceneIndexCreator, IUmbracoIndexesCreator
        /// <summary>_profilingLogger</summary>
        private readonly IProfilingLogger _profilingLogger;
        /// <summary>_localizationService</summary>
        private readonly ILocalizationService _localizationService;
        /// <summary>_publicAccessService</summary>
        private readonly IPublicAccessService _publicAccessService;
        /// <summary>
        /// AFExamineIndexCreator
        /// </summary>
        /// <param name="profilingLogger"></param>
        /// <param name="localizationService"></param>
        /// <param name="publicAccessService"></param>
        public AFExamineIndexCreator(IProfilingLogger profilingLogger, ILocalizationService localizationService, IPublicAccessService publicAccessService)
            _profilingLogger = profilingLogger;
            _localizationService = localizationService;
            _publicAccessService = publicAccessService;
        /// <summary>
        /// Create
        /// </summary>
        /// <returns>IEnumerable(IIndex)</returns>
        public override IEnumerable<IIndex> Create()
            var index = new UmbracoContentIndex("AFExamineRepositoryIndex", // Name of the Indexer
                CreateFileSystemLuceneDirectory("AFExamineRepositoryIndex"), // File System Index
                new FieldDefinitionCollection(
                    new FieldDefinition("date", FieldDefinitionTypes.DateTime),
                    new FieldDefinition("title", FieldDefinitionTypes.FullText),
                    new FieldDefinition("docCategory", FieldDefinitionTypes.FullText),
                    new FieldDefinition("bodyText", FieldDefinitionTypes.FullText),
                    new FieldDefinition("docFile", FieldDefinitionTypes.FullText)),
                new StandardAnalyzer(Version.LUCENE_30),
                _profilingLogger,
                _localizationService,
                new ContentValueSetValidator(true, includeItemTypes: new string[] { "doc" },  excludeItemTypes: new string[] { "homepage", "docFolder", "ricerca" })
            return new[] { index };
    /// <summary>
    /// AF Examine Composer
    /// </summary>
    public class AFExamineComposer : IUserComposer
        /// <summary>
        /// Compose
        /// </summary>
        /// <param name="composition"></param>
            composition.Components().Append<AFExamineComponent>();
            composition.RegisterUnique<AFExamineIndexCreator>();
    /// <summary>
    /// AF Examine Component
    /// </summary>
    public class AFExamineComponent : IComponent
        /// <summary>_examineManager</summary>
        private readonly IExamineManager _examineManager;
        /// <summary>_afExamineIndexCreator</summary>
        private readonly AFExamineIndexCreator _afExamineIndexCreator;
        /// <summary>
        /// AFExamineComponent
        /// </summary>
        /// <param name="examineManager"></param>
        /// <param name="afExamineIndexCreator"></param>
        public AFExamineComponent(IExamineManager examineManager, AFExamineIndexCreator afExamineIndexCreator)
            _examineManager = examineManager;
            _afExamineIndexCreator = afExamineIndexCreator;
        /// <summary>
        /// Initialize
        /// </summary>
        public void Initialize()
            // Because the Create method returns a collection of indexes,
            // we have to loop through them.
            foreach (var index in _afExamineIndexCreator.Create())
                _examineManager.AddIndex(index);
        /// <summary>
        /// Initialize
        /// </summary>
        public void Terminate() { }
    The result view:
    @using AFStarterKit.AFBusinessLogic;
        // Get query param
        string searchTerm = (string.IsNullOrEmpty(Request["query"])) ? string.Empty : Request["query"];
        if (!string.IsNullOrEmpty(searchTerm))
            // Perform the search
            if(ExamineManager.Instance.TryGetIndex("AFExamineRepositoryIndex", out var index))
                // Get Searcher
                var searcher = index.GetSearcher();
                // Get Results
                var results = searcher.Search(searchTerm, int.MaxValue).OrderByDescending(x => x.Score); // Here I want to orderbydescending by field date
                // Show results
                if (!results.Any())
                    <div class="alert alert-info" role="alert">
                        No results with query "<strong><i>@searchTerm</i></strong>"
                else
                    <div class="alert alert-success" role="alert">
                        @{ string resultMessage = (@results.Count() == 1) ? "result"  : "results"; }
                        <p>Find <strong><i>@results.Count()</i></strong> @resultMessage with query <strong><i>@searchTerm</i></strong></p>
                    <ul>
                        @foreach (var result in results)
                            if (result.Id != null)
                                var node = Umbraco.Content(result.Id);
                                <li>
                                    <a href="@node.Url">@node.Name</a>
                                </li>
                    </ul>
        else
            <div class="alert alert-warning" role="alert">
                Insert at least one word to start search
    I would to modify (in search view) the code to show results ordered by "date" field (descending)
    Can anyone help me?
  • Erik Eelman 82 posts 322 karma points
    Oct 16, 2019 @ 15:36
    Erik Eelman
    Hi Adriano,
    I believe you can use something like this in your view:
       var criteria = searcher.CreateQuery(IndexTypes.Content, BooleanOperation.Or);
        var examineQuery = criteria.Field("fieldToSearch", searchTerm);
        examineQuery.OrderByDescending(new SortableField("date"));
        var results = examineQuery.Execute();
    Kind regards, Erik
    Oct 17, 2019 @ 09:11
    Adriano Fabri
    Thank you, but I already specified the fields in the "AFExamineIndexCreator" class
    So...in the view I must only launch the search with the command
    var results = searcher.Search(searchTerm, int.MaxValue).OrderByDescending(x => x.Score).OrderBy(new SortableField("date", SortType.Long));
    I think that it is heare that I must specify my OrderByDescending by date...but I don't know how.
    I tried this code but it don't function:
    var nodes = results.OrderByDescending(new SortableField("date"));
    But I receive this error message:
    Compiler Error Message: CS0246: The type or namespace name 'SortableField' could not be found
    Oct 17, 2019 @ 09:32
    Erik Eelman
    You are missing a using at the top of your page (below @using AFStarterKit.AFBusinessLogic;)
    @using Examine.Search
    And like Ismail said, you don't need the Order by score since it is the default sorting order. Can you try this:
    var results = searcher.Search(searchTerm, int.MaxValue).OrderByDescending(new SortableField("date"));
    Oct 17, 2019 @ 12:43
    Adriano Fabri
    Found the solution...thank you!
    Oct 16, 2019 @ 16:12
    Ismail Mayat
    Just as fyi I see alot of .OrderByDescending(x => x.Score); there is no need to order by score as that is the default ordering.
    Adriano Fabri
    Thank you
    Oct 17, 2019 @ 12:41
    Adriano Fabri
    Finally, I found the solution.
    This is the right code tested in my view:
                          .OrderByDescending(f => f.Values["date"])
                          .ThenBy(f => f.Values["title"])
    Many thanks to all for the support
    Adriano
    Oct 17, 2019 @ 13:19
    Ismail Mayat
    Adriano,
    You are sorting in memory using linq, which will work but as you are pulling back all results if you match alot it will start to run slow and if load hits that search results page it will run even slower.
    Ideally you need to get lucene to sort for you.
    Oct 17, 2019 @ 14:06
    Adriano Fabri
    ok Ismail.
    Can you give me an example about that?
