  • Darcy Goettling 3 posts 73 karma points
    Oct 18, 2019 @ 22:55
    Darcy Goettling
    /umbraco/AuthorizeUpgrade?redir=%2finstall% - please help!
    Hi - We are working to configure a clone of an existing environment - meaning we cloned the the entire server...
    SQL Server is good to go, password screen comes up and the login script triggers it to go to this upgrade process and I am unable to log into the admin back office. Any help would be awesome!...
  • Peter Cort Larsen 421 posts 1038 karma points
    Oct 19, 2019 @ 10:07
    Peter Cort Larsen
    Hi.
    Please be absolutely sure it's the correct database. I had the same problem, cause I received an old database from the client.
    Oct 21, 2019 @ 13:56
    Darcy Goettling
    I have verified through ODBC connection and web config we are pointing to the same server in current prod and this clone.
    Login to admin back console appears to work, only to redirect me to the "upgrade panel" even though versions are same
    Oct 21, 2019 @ 16:22
    Darcy Goettling
    Well well...found the problem. Unknown to our team there was another copy of the Umbraco supporting database was installed on the server (it is shared infrastructure).
    The issue boiled down to Web Config - for whatever reason, even on the clone we ended up with an incorrect db.
