Urgent help pls: 'failed to get next sibling with id=3694'
Hi all,
I have big problem which I have noticed after last Umbraco update, but it could be something else, I am not sure that upgrade is the reason.
I have code where I can upload and delete images in Media section from the fronted of my website.
I have few fields where I can upload images. For example if I try to upload 1st image its okay, than if I upload one more image, again its all good, after that If I delete 1 od this images programatically it works good and than sometimes, not always which is so wierd i get this error:
Umbraco.Core.Exceptions.PanicException: 'failed to get last child with id=-1'
In this line:
IMedia uploadFile = Services.MediaService.CreateMediaWithIdentity(model.File.FileName, mediaFolderId, "Image");
This is my code for image upload to media section:
Hi all,
In this line: IMedia uploadFile =
Services.MediaService.CreateMediaWithIdentity(model.File.FileName, mediaFolderId, "Image");This is my code for image upload to media section:
If i continue after that error and than try to delete some other Image i get this error:
On this line:
Please somebody help me with this, i can provide more informations if needed for better understunding.
BR
Josip
Hi Josip,
sounds like your hitting this issue (or something related to it) here https://github.com/umbraco/Umbraco-CMS/issues/6698
it will be properly fixed in the next release 8.2.1 but the end of the issue has an updated dll, you can use to get around it.
https://github.com/umbraco/Umbraco-CMS/issues/6698#issuecomment-543790291
Hi Kevin, thank you verry much for your super fast answer.
You are lifesaver.
BR
Josip
same issue here.
