  • bh 444 posts 1544 karma points
    Oct 23, 2019 @ 18:43
    bh
    Help with Surface Controller
    I have a page that loads the last 12 months of press releases. At the bottom is a button that attempts to append the 6 prior press releases via ajax.
    I'm getting this error when my Surface Controller returns my Partial View. Cannot bind source type myproject.Models.ccPressOlder to model type Umbraco.Web.Models.RenderModel.
    My architecture is thus:
    • View named Media.cshtml
    • Partial view named ccPress.cshtml (loads 12 months of press)
    • Partial view named ccPressOlder.cshtml
    • JavaScript main.js does the ajax bit
    • Surface controller PartialViewController.cs
    • Model named ccPressOlder.cs for strongly typing the content sent to my partial view named ccPressOlder.cshtml
    ccPress.cshtml
    <div class="d-block mx-auto text-center news-btn">
        <a href="#" id="btnPressLoadMore" class="btn green d-inline-block mx-auto">LOAD MORE <i class="fas fa-caret-right"></i></a>
        <div id="ccPressOlderContent"></div>
        <input type="hidden" id="hidNodeID" value="@UmbracoContext.Current.PageId" />
    main.js
    $(function () {
        $('#btnPressLoadMore').click(function(e) {
            e.preventDefault();
            var oldCount = $('.desktop .story').length;
            var oldPressUrl = '/umbraco/surface/PartialView/Index?name=ccPressOlder&counter=' + oldCount + '&id=' + $('#hidNodeID').val()
            $.ajax({
                url: oldPressUrl,
                type: 'GET',
                cache: false,
                success: function (data) {
                    console.log('getting older press step 2');
                    $('#ccPressOlderContent').html(data);
    ccPressOlder.cs
    namespace myproject.com.Models
        public class ccPressOlder
            public IEnumerable<IPublishedContent> OlderPressList { get; set; }
    namespace myproject.Controllers
        public class PartialViewController : SurfaceController
            public ActionResult Index(string name, Int32 counter, Int32 id)
                var page = Umbraco.TypedContent(id);
                var oneYearAgo = DateTime.Today.AddYears(-1);
                var pressList = page.Children.Where(x => x.GetPropertyValue<DateTime>("newsDetailDate") < oneYearAgo).Where(x => x.IsVisible()).Skip(counter).Take(6).OrderByDescending(x => x.GetPropertyValue<DateTime>("newsDetailDate"));
                var oldPressList = new myproject.Models.ccPressOlder { OlderPressList = pressList } ;
                return PartialView(name, oldPressList);
    ccPressOlder.cshtml
        var myOlderPressList = Model.Content.GetPropertyValue<IEnumerable<IPublishedContent>>("OlderPressList");
    <div class="row no-gutters d-none d-sm-block desktop">
        @foreach (var press in myOlderPressList)
            @*markup goes here*@
  • Jonathan Distenfeld 105 posts 618 karma points
    Oct 24, 2019 @ 05:45
    Jonathan Distenfeld
    Hi bh,
    try updating your ccPressOlder.cshtml to following:
    @model myproject.Models.ccPressOlder
        var myOlderPressList = Model.OlderPressList;
    ~ Jonathan
    Oct 24, 2019 @ 13:18
    bh
    @JonathanDistenfeld a million thanks for wading through my long OP and coming up with the spot-on solution!!! Can't thank you enough you were 100% correct! Thank you!
