On getting the media moved to an Azure Blob Storage. I don't have any problem with the first part, as far as the images being served from the "media" blob. But the ImageProcessor does not work anymore after converting to an Azure Blob Storage. I'd like to store the cached images in the azure blob, but don't need a CDN (maybe using the blob storage for the cached images requires the CDN?). What is incorrect about the tutorial above?
I've upgraded all ImageProcessor stuff that I can.
ImageProcessor.dll - 2.7.0.100
ImageProcessor.Web.dll - 4.8.2.0
ImageProcessor.Web.Plugins.AzureBlobCache.dll - 1.5.0.100 (its not clear if this file is even required)
Umbraco 7.5.14 ImageProcessor not working with Azure Blob Storage
I've followed this tutorial: https://our.umbraco.com/Documentation/Extending/FileSystemProviders/Azure-Blob-Storage/index-v7
I've upgraded all ImageProcessor stuff that I can. ImageProcessor.dll - 2.7.0.100 ImageProcessor.Web.dll - 4.8.2.0 ImageProcessor.Web.Plugins.AzureBlobCache.dll - 1.5.0.100 (its not clear if this file is even required)
Here is are some of the config files: https://gist.github.com/bgilb5/1ee2a3516a1b2eae228407967f0d8e98
If anyone else ends up with this issue you need to add Container to the CloudImageService settings:
I tried to add Container as well, but still no luck!
