I am attempting to install Umbraco V.8.2. The installation is on a new VM server, running Windows Server 2016 Standard, that was created for this purpose.
The database is to exist on a separate server running SQL Server 2017. I have created the empty database and created a new login and user for this database. The user is a Windows user (in our Active Directory) and has been given datareader, datawriter, owner and public roles for the database.
I have unzipped Umbraco on the new server and opened it in Visual Studio. I built the solution, then ran the app in non-debug mode in VS.
The install proceeds okay, until I get to the database install section. I provide the appropriate credentials for the new user, the db server name and the db name, but continually receive a 'Could not connect to database' error. When I check the logs in SQL Server, I see the following:
Login failed for user *. Reason: Could not find a login matching the name provided. Error: 18456, Severity: 14. State: 5.
No matter what I try, it is the same result. I have added the domain name in front of the user, added the domain name to the server name, etc.
No luck. I'm hoping someone can assist me with this. I need to get this project started.
Update: I checked the error message and it is telling me that the user name is not valid. This can't be, because I was able to login to SQL Server with that username and password. Weird.
Is it possible that its an issue with windows authentication vs sql authentication with SQL server? When I run into these hiccups I try to connect via SQL Server Management Studio instead of directly to the server. You can set the authentication type, see what permissions you have, etc.
Apologies if that's what you were saying by "login to SQL Server with that username and password".
You should also check if Windows Firewall or some other network related issue is blocking the connection from the web server to the database server. Your connection via Management Studio may not be behind the same restrictions.
Installation issue with Umbraco 8.2
Hello all.
I'm hoping someone can help with this.
Thanks in advance. Bill Even / CTG, Inc.
-Amir
Hi Amir,
That is what I meant. I can login using SSMS with the same credentials I am trying to use during the installation.
Thanks for the help.
Bill
There was an issue with firewall blockage, but I have now been given a new subnet that hosts a dedicated SQL Server and development machine.
I'm still having issues, but I will flag this as solved and create a new discussion.
Thanks, Bill Even
