  • Mario Lopez 168 posts 958 karma points MVP 5x c-trib
    Oct 29, 2019 @ 21:48
    Mario Lopez
    Load balancing and umbracoApplicationUrl
    Hey people, just reading the docs I can't figure out what the value of umbracoApplicationUrl must be in a load balanced configuration. Should each machine (public/master) point to the master's umbraco url or each one to its own umbraco url?
    Thanks.
  • Jeffrey Veer 41 posts 308 karma points
    Oct 30, 2019 @ 08:14
    Jeffrey Veer
    Hi Mario,
    The umbracoApplicationUrl should be set to reach itself. In case of a loadbalanced environment this should be the url to reach it's own machine.
    Regarding the documentation found here: https://our.umbraco.com/documentation/reference/config/umbracosettings/#webrouting
    umbracoApplicationUrl: defines the Umbraco application url, i.e. how the server should reach itself. By default, Umbraco will guess that url from the first request made to the server. Use that setting if the guess is not correct (because you are behind a load-balancer, for example). Format is: "http://www.mysite.com/umbraco" i.e. it needs to contain the scheme (http/https), complete hostname, and Umbraco path.
    Oct 30, 2019 @ 10:19
    Mario Lopez
    Thanks, I missed the 'itself' part. :/
    I'm just having a real weird issue with a load balanced scenario and not sure if was setting that up correctly.
    Oct 30, 2019 @ 10:21
    Jeffrey Veer
    What's the issue you are facing? Might be able to help you there.
    Oct 30, 2019 @ 21:23
    Mario Lopez
    I have a CI deployment from Octopus, when this happens the slaves throw a 'The Xml cache is corrupt. Use the Health Check data integrity dashboard to fix it.' error
    In the master's logs I get lots of 'Umbraco.Web.UmbracoModule - Status code is 404 yet TrySkipIisCustomErrors is false - IIS will take over'
    Also in the master I get errors recreating the Examine indexes and the app shuts down.
    Lots of errors :( Not sure if they are related or what.
    EDIT: If I republish content then all works... until I redeploy.
    Nov 01, 2019 @ 04:13
    Mario Lopez
    The issue was that App_Data was being deleted in every deployment. The Slaves didn't like that :(
