  • Jay 425 posts 652 karma points
    Nov 01, 2019 @ 11:57
    Jay
    PageCacheRefresher in Umbraco V8
    Anyone knows what's the new PageCacheRefresher events on distributed servers on the new Umbraco V8?
    Nov 01, 2019 @ 20:44
    Marc Goodson
    102
    Hi JLon
    I think you might be after this?
    public class RegisteringCacheUpdatedEvents : IUserComposer
        public void Compose(Umbraco.Core.Composing.Composition composition)
            ContentCacheRefresher.CacheUpdated += ContentCacheRefresher_CacheUpdated;
            MediaCacheRefresher.CacheUpdated += MediaCacheRefresher_CacheUpdated;
        private void MediaCacheRefresher_CacheUpdated(MediaCacheRefresher sender, CacheRefresherEventArgs e)
           //media cache updated
        private void ContentCacheRefresher_CacheUpdated(ContentCacheRefresher sender, CacheRefresherEventArgs e)
            //content cache updated!
    regards
    Marc
    Nov 04, 2019 @ 12:00
    Jay
    Thanks Marc :)
    Dec 04, 2019 @ 15:44
    Jay
    Hey Marc,
    Do you also know if there's a way we can detect the type of the event.
    Eg if it's a Save and Publish or even if it's Unpublishing on a content?
    When I debug through the e.MessageObject within the ContentCacheRefresher_CacheUpdated()
    It keeps coming back as MessageType.RefreshByPayload for Save and Publish or Unpublishing
    Dec 07, 2019 @ 08:22
    Marc Goodson
    2
    Hi Jeric
    I can't find a good example of this, and I'm guessing a little but I think knowing the MessageType is RefreshByPayload, means you can cast the MessageObject into they type of Payload, and loop through each Payload, and it's ChangeType to determine a little about what is going on.
    Have a look at the Examine ContentCacheRefresherUpdated event handling implementation in the core:
    https://github.com/umbraco/Umbraco-CMS/blob/13488be0a3280c966ca5115c1cf75cc1979e5819/src/Umbraco.Web/Search/ExamineComponent.cs#L133
      foreach (var payload in (ContentCacheRefresher.JsonPayload[])args.MessageObject)
                    if (payload.ChangeTypes.HasType(TreeChangeTypes.Remove))
                        // delete content entirely (with descendants)
                        //  false: remove entirely from all indexes
                        DeleteIndexForEntity(payload.Id, false);
    The ChangeTypes enum is here;
    public enum TreeChangeTypes : byte
        None = 0,
        // all items have been refreshed
        RefreshAll = 1,
        // an item node has been refreshed
        // with only local impact
        RefreshNode = 2,
        // with branch impact
        RefreshBranch = 4,
        // an item node has been removed
        // never to return
        Remove = 8,
    So you should be able to tell the difference between an Unpublish and a Publish.
    regards
    Marc
    Dec 11, 2019 @ 12:19
    Jay
    Thanks Marc
