  • Christina 127 posts 390 karma points notactivated
    Nov 03, 2019 @ 20:50
    Christina
    Actionlink with parameters generate /umbraco/Surface/myController?id=3
    Hi I using actionlink for pass parameter to a surfacecontroller.
    @Html.ActionLink(l.SlopeName, "Index","Slopestatus",new {level = l.SlopeValue }, new { @class = Request["level"] == l.SlopeValue ? "active" : "" })
    Links that are generated /umbraco/Surface/Slopestatus?level=easy I want /PageId?level=easy
      public ActionResult Index(Slopestatus model,string level=null )
    Hope someone can help /Christina
  • AddWeb Solution Pvt. Ltd 109 posts 360 karma points
    Nov 05, 2019 @ 07:22
    Hello Christina,
    if I have understood correctly, you want the name to be "PageId" instead of "Slopestatus" in the call. to achieve this you can replace "slopestatus" with "PageId"
    Nov 05, 2019 @ 08:47
    Christina
    Thanks I solved it without ActionLink. My problem was that the link was generated as / umbraco / Surface / Slope status and I wanted the page id = / 1500.
