I am using nested content frequently in my solution and I fail a bit when I try to unit test them.
I fetch the nested content with this line of code
var elements = pageContent.Value("nestedContentAlias", defaultValue: Enumerable.Empty<IPublishedElement>());
And this works fine when the site is run. But how do I mock this? I've tried alot of different approaches for this. At first, when the test was run, Umbraco threw error when above line was run.
System.InvalidCastException
HResult=0x80004002
Message=Unable to cast object of type 'System.Collections.Generic.List`1[Umbraco.Core.Models.PublishedContent.IPublishedElement]' to type 'Umbraco.Core.Models.PublishedContent.IPublishedValueFallback'.
Source=Umbraco.Core
StackTrace:
at Umbraco.Core.FactoryExtensions.GetInstance[T](IFactory factory)
at Umbraco.Core.Composing.Current.getPublishedValueFallback()
at Umbraco.Web.Composing.Current.getPublishedValueFallback()
I managed to bypass this by doing this in the test setup (row 2):
foreach(var element in elements)
var stringValue = element.Value<string>("stringAlias");
but stringValue above is always null.
Can someone give examples on how I can mock a nested content where the IPublishedElement contains mocked properties?
Mocking Nested Content in unit tests
Hi everyone,
I now get items as IEnumerable
Kind regards, Martin
