  • Rik Helsen 670 posts 873 karma points
    Jun 14, 2012 @ 10:49
    Rik Helsen
    Migrating a website from 5.1 to 4.7.2 -
    So.. we've got an unreliable umbraco v5 website, containing a bunch of stuff to move from V5 to 4.7.2
    This includes:
    • Document types (not currently possible to migrate?)
    • Dictionary items (not currently possible to migrate?)
    • MVC masterpages with inheritance (need to me re-done ?)
    • partials (these can easily be migrated to razor snippets)
    • media items (not currently possible to migrate?)
    • content nodes (i could export this outputting each item as xml and try to use CMS import, but what about relationships?)
    • relations between those content nodes (pickers)
    • relations between content and media (pickers)
    • Contour forms
    I'll be trying and go into each of these items and find a way to migrate them to the older version. all help/suggestions are appreciated.
  • Gunnar Liljas 18 posts 42 karma points
    Jun 14, 2012 @ 13:33
    Gunnar Liljas
    What should be possible.. (will think about the actual process later..)
    Simple doctypes should be possible. Multi-inheriting could be be solved (ish...) by creating new, merged types or possibly by using mixins.
    Should be possible.
    Tricky. Simple layouts can be turned into templates/masters
    Yup
    The structure is different, but it should be possible to at least fill the media tree.
    A bit different, but if the structure isn't too complex it could be done.
    I guess v4 relations could handle most of it
    Sure thing
    • Contour forms
    No idea, yet.
    /G
