  • Fredrik Esseen 610 posts 906 karma points
    Nov 30, 2012 @ 13:09
    Fredrik Esseen
    Browse cshtml file
    Im downgrading a site that loads info from a partial view made in Umbraco 5 like this:
    $('#div').load('/folder/the_chtml_file.cshtml');
    We're trying to load a div with info dynamically from the partial view.
    It works in the Umbraco 5 solution but when I create a cshtml file in Umbraco 4.11 and try to browse it the resource cant be found. I would at least want it to return this error that I get in 5:
    Unable to cast object of type 'ASP._Page_Views_produkter_Index_cshtml' to type 'System.Web.IHttpHandler'.
    Ive noticed that runAllManagedModulesForAllRequests="true" already is in the web.config so that not the problem.
    Except that there is a separate web.config in the Views folder. Ive added the same there but no difference.
    Is it a configuration I have to do in IIS or is there another solution?
