  • Fredrik Esseen 610 posts 906 karma points
    Dec 05, 2012 @ 14:33
    Fredrik Esseen
    Use old usercontrol in 4.11 mvc
    I have a usercontrol from an old project that I would like to use in my 4.11 mvc project.
    The usercontrol includes a button with postback. Is it possible to use the usercontrol without needing to totally rewrite it?
    I suppose the postback is not gonna work?
    Dec 17, 2012 @ 21:47
    Hi Froad
    Don't know if you have already found an answer to the above elsewhere.
    But as far as I know you should be able to use the usercontrol just fine in 4.11 - MVC is not enabled by default and Umbraco should accept your usercontrol as usual.
    Hope this helps.
    Dec 19, 2012 @ 12:29
    Fredrik Esseen
    Forgot to mention that i use MVC and wondered if I could reuse the usercontrol.
    I rewrote it to razor instead :)
    Thx anyway!
