  • Ulrik Ricco Hansen 6 posts 25 karma points
    Oct 30, 2013 @ 21:54
    Ulrik Ricco Hansen
    2
    From Umbraco 4 to 6 and from uCommerce 2 to 4
    Finally, we launchet one of the biggest upgrade of Umbraco / uCommerce / Windows servers I have ever been involved in.
    From Umbraco 4.7.0 to the latest 6.1.5 .
    From uCommerce 2.0.5 to the latest 4.1.4 .
    Refactorering solution to fewer projects.
    From Win7 , IIS7 , MSSQL2008 to latest WinServer 2012 IIS8 , MSSQL 2012.
    As previously with TeamCity , Subversion and a pipeline of 4 servers (local and demo delveloper , stage , live ) .
    http://mit.jp.dk.">Where: Jyllands- Posten commercial team on http://mit.jp.dk . One of Denmark's largest newspapers , Jyllands- Posten - have here a store that sells subscriptions and special offers for subscribers.
    A team of 5 men worked over a month to get all updates implemented. A large part of the code that uses uCommerce 's API has been rewritten . The biggest challenges has been setup : config -files and assemblies , weird hacks and undocumented new guidelines - especially uCommerce has been a challenge . Another major challenge has been automated tests that run in a separate project - which also needed updating.
    Such large changes have not been able to be part of a normal deployment . We have set up a parallel line with the upgrade project and continuously synchronized with normal project which regularly had small updates .
    A parallel line of course, provides world of challenges in relation to eg dns , permits inside and outside gmz since we use a range of services from third parties.
    So - here's how we did it :
    A : Upgrade uCommerce and solution files
    - Install uCommerce packets from Umbraco backend. Stepwise. We found this model works: 2.0.5 - > 2.6 -> 2.6.1 -> 3 - > 4
    - During the upgrade: the code and settings using uCommerce must also be upgraded.
    B : Upgrade Umbraco
    - From an empty folder only with Umbraco 6 : Specify the database and run the installer
    - Merge Umbraco 's web.config with your own . Do the same for other config files
    C : Use the upgraded database just replace the files with the updated files ( from A except for the new merged config files)
    Oh - by the way :
    Lots of things can go wrong in such a big upgrade. I will post some more details on our.umbraco.org in the coming days.
    Ulrik Ricco Hansen, [email protected]
    Certified Umbraco developer level 2
